2026-01-20 海外站 - DJ CHARTS EDM TOP 精选 (TECHNO 130 TRACKS)
A.Paul - Orchid (2026 Remix)[edmtop.com]
A.Paul - Shellshock (2026 Remix)[edmtop.com]
Acina - I Call You (Extended Mix) - [edmtop.com]
ADAM PACE, NYTK - Put It Up (Original Mix)[edmtop.com]
AILS, Gitecdj - Go Back (Extended Mix)[edmtop.com]
AILS, Gitecdj - Never Back (Extended Mix) - [edmtop.com]
Alinep - Jeprox (Original Mix)[edmtop.com]
Alinep - Sponklong (Original Mix) - [edmtop.com]
Anthony Spallino, Aurelien Stireg - Dark Fall (Breaks Mix)[edmtop.com]
Anthony Spallino, Aurelien Stireg - Dark Fall (Rework Mix)[edmtop.com]
Anthony Spallino, Aurelien Stireg - Dark Fall (Southsoniks Remix)[edmtop.com]
Atlanthes - Clouds (Original Mix)[edmtop.com]
Atlanthes - Fractal Dream (Original Mix) - [edmtop.com]
Atlanthes - Reflejo Perdido (Original Mix)[edmtop.com]
Atlanthes - Tacto Invisible (Original Mix) - [edmtop.com]
Augusto Taito - Antihero (Berlin Edit)[edmtop.com]
Augusto Taito - Antihero (Original Mix)[edmtop.com]
Augusto Taito - LOOP1 (Original Mix) - [edmtop.com]
Augusto Taito - LOOP2 (Original Mix)[edmtop.com]
Augusto Taito - Obsexed (Original Mix)[edmtop.com]
Augusto Taito - Warehouse Foundations (Original Mix) - [edmtop.com]
Belocca - Burn Me Down (Extended)[edmtop.com]
Belocca - Raw Desire (Extended)[edmtop.com]
Bent - Cutoff Line (Original Mix)[edmtop.com]
Bent - Cutoff Line (Sanderjammes Remix) - [edmtop.com]
Bent - Cutoff Line (Tetra Hydro Remix)[edmtop.com]
Bent - Output (Original Mix)[edmtop.com]
Bent - Output (SYMO Remix) - [edmtop.com]
Conrad Pack - False Dawn (Original Mix)[edmtop.com]
Conrad Pack - In Sleep (Original Mix) - [edmtop.com]
Conrad Pack - Inland (Original Mix)[edmtop.com]
Conrad Pack - Method (Original Mix)[edmtop.com]
Conrad Pack - Motion (Original Mix) - [edmtop.com]
Conrad Pack - Regolith (Original Mix)[edmtop.com]
Darius Rose - Hypnotize (Extended Mix)[edmtop.com]
Decka - Evolution (Original Mix) - [edmtop.com]
Decka - Fuse (Original Mix)[edmtop.com]
Decka - Obscure Arcade Game (Original Mix)[edmtop.com]
Decka - Tunnel (Original Mix)[edmtop.com]
DECKERT (DK) - Into The Unknown (Original Mix) - [edmtop.com]
Deetron - Flow (Breakbeat Mix)[edmtop.com]
Deetron - Flow (Chord Dub)[edmtop.com]
Deetron - Flow (Original Mix) - [edmtop.com]
Deroz, Ariovistus - Red Light (Original Mix)[edmtop.com]
Droplex - Black On Black (Original Mix)[edmtop.com]
Eddy D'Amato - Timeclock (Original Mix) - [edmtop.com]
ESTORA - I Do What I Want (Extended Mix)[edmtop.com]
Fernando Lagreca - Chorito (Original Mix)[edmtop.com]
Fernando Lagreca - Kosmonauten (Original Mix) - [edmtop.com]
Goncalo M - Hostile Reflections (Original Mix)[edmtop.com]
Goncalo M - Underrated (Original Mix)[edmtop.com]
HOF(DE) - Kakusei (Extended Mix) - [edmtop.com]
HYPNOZA - Lost In Your Eyes (Extended Mix)[edmtop.com]
Innervoix, Rodri XXX - Solid State (Original Mix)[edmtop.com]
Jay Lumen - Bounce (Original Mix) - [edmtop.com]
JKS - Spectra (Original Mix)[edmtop.com]
JKS, Lacchesi - Get Johnson (Original Mix)[edmtop.com]
JKS, Lacchesi - High & Dry (Original Mix) - [edmtop.com]
Jorg Rodriguez - Jumper (Original Mix)[edmtop.com]
Jorg Rodriguez - Ladder (Original Mix) - [edmtop.com]
Jorg Rodriguez - NRG Meets HRG (Original Mix)[edmtop.com]
Jorg Rodriguez - Substances (Original Mix) - [edmtop.com]
K-Fel, Laurent Mauritz - Battlefield (Original Mix)[edmtop.com]
K-Fel, Laurent Mauritz - Oasis (Original Mix)[edmtop.com]
K-Fel, Laurent Mauritz - Rebel (Original Mix) - [edmtop.com]
KVTS - Beyond The Static (Original Mix)[edmtop.com]
KVTS - Lost Pattern (Original Mix)[edmtop.com]
KVTS - Pulsepath (Original Mix) - [edmtop.com]
KVTS - Signal Overwrite (Original Mix)[edmtop.com]
KVTS - Static Recall (Original Mix)[edmtop.com]
Lacchesi - Overhead, The Albatross (Original Mix) - [edmtop.com]
Lautaro Ibañez - Empty Concern (Original Mix)[edmtop.com]
Mauer - Pulse Without End (Original Mix)[edmtop.com]
Mauer - Quantum Circuit (Original Mix)[edmtop.com]
Mauer - Voltage Ritual (Original Mix) - [edmtop.com]
Mauer - Zwei Kontakte (Original Mix)[edmtop.com]
Mazdem - Techno Overdose (Original Mix) - [edmtop.com]
Michael Mayer - Cry Me A Raver (Original Mix)[edmtop.com]
Michael Mayer - Don't Sync With My Tag (Original Mix)[edmtop.com]
Michael Mayer - It Isn't What It Isn't (Original Mix)[edmtop.com]
Mikkel Metal - Rebuild (Original Mix)[edmtop.com]
Mython - Abilene (Original Mix) - [edmtop.com]
Mython - Condition (Original Mix)[edmtop.com]
Mython - Hatch (Original Mix)[edmtop.com]
Mython - Viable (Original Mix) - [edmtop.com]
Nick Guiducci - Run (Extended Mix)[edmtop.com]
Nikoretti - Control (Original Mix)[edmtop.com]
ORTIZ KAREV - Unit 47 Assault (Original Mix)[edmtop.com]
Patrick Müller - Broskis In The World (Original Mix) - [edmtop.com]
Patrick Müller - Hard Raver (Original Mix)[edmtop.com]
RanchaTek - New Order (Original Mix)[edmtop.com]
RanchaTek - Reflux (Original Mix) - [edmtop.com]
Rangel Coelho - Rabbit (Original Mix)[edmtop.com]
Rangel Coelho - Samsara (Original Mix) - [edmtop.com]
Reinier Zonneveld, Fēlēs - Acid (Original Mix)[edmtop.com]
RIKSO, ROMEK666 - 9mm (Original Mix)[edmtop.com]
Sabura - Level Up (Extended Mix) - [edmtop.com]
Sabura - When The Bass Goes Up (Extended Mix)[edmtop.com]
Sabura - When The Bass Goes Up (Innervoix Extended Remix)[edmtop.com]
Salkantay - Dark Chant (Original Mix) - [edmtop.com]
Salkantay - Faded (Original Mix)[edmtop.com]
Samuel L Session - A Bastards Work Is Never Done (Deetron Playmate Rework)[edmtop.com]
Samuel L Session - A Bastards Work Is Never Done (Deetron Re-Cut)[edmtop.com]
Samuel L Session - A Bastards Work Is Never Done (Samuel L Session Remix)[edmtop.com]
Samuel L Session - A Bastards Work Is Never Done (Steve Bicknell Mix)[edmtop.com]
TempleMonks - Code 1 (Original Mix) - [edmtop.com]
The Rocketman - Bounce Like That (Extended Mix)[edmtop.com]
Upwellings - E (Original Mix) - [edmtop.com]
Upwellings - F (Original Mix)[edmtop.com]
Upwellings - G (Original Mix)[edmtop.com]
Upwellings - H (Original Mix) - [edmtop.com]
Upwellings - I (Original Mix)[edmtop.com]
Upwellings - J (Original Mix)[edmtop.com]
Vincent (IT) - 6am (Original Mix) - [edmtop.com]
Vincent (IT) - Boiler Room (Original Mix)[edmtop.com]
Vincent (IT) - Valve Core (Original Mix) - [edmtop.com]
Vkn.modular - Anomaly In The System (Original Mix)[edmtop.com]
Vkn.modular - Equilibrium (Original Mix)[edmtop.com]
Vkn.modular - Molecular Deconstruction (Original Mix) - [edmtop.com]
Vkn.modular - Spacial Interferences (Original Mix)[edmtop.com]
WE 3AT BEATS, WILLS - The Heist (Original Mix)[edmtop.com]
Yrsen - Bunong People (Original Mix) - [edmtop.com]
Yrsen - Fantasmagoria (Original Mix)[edmtop.com]
Yrsen - Nommalath (Original Mix)[edmtop.com]
Yrsen - The Sunflower Movement (Original Mix) - [edmtop.com]
Yrsen, Gannein - Nordic (Original Mix)[edmtop.com]
8288, Alex Sauer - Kein Morgen (Original Mix)[edmtop.com]
A.Paul - Cornetas (2026 Remix) - [edmtop.com]
A.Paul - Hipnotika (2026 Remix)[edmtop.com]
A.Paul - Mirabolante (2026 Remix)[edmtop.com]
[netdisk href="https://pan.baidu.com/s/1OL6wncv2Hp86M1eJweYPpQ?pwd=9999" wpname="baidu" pass="" reply="1"]
0 0 4 举报
